Hello everyone
so i just got a Nissan Cedric Y34, and its got the VQ30DD engine in it, can i be enlightened with how i can turbocharge this engine (available turbo kits, hassle, etc) I am in Canada, and also id like to know how much this process should cost, how much power i can expect to get, etc :)
Edited by 4ventador
https://www.sau.com.au/forums/topic/463595-vq30dd/
Someone I know in New Zealand went through all this but his turbo kit was remains of a half-cut from a turbo Y34. There is no aftermarket turbo kit for Y34 (highly unlikely there would be one available in Japan).
The russians have a forum on Nissans that may be useful. http://forums.drom.ru/nissan-cedric-gloria-cima/
If you want to spend money on parts you'll have to browse endlessly on Yahoo Auctions. There are some nice bits second-hand you just have to be patient sometimes. http://translate.google.com/translate?hl=en&sl=auto&tl=en&u=http%3A%2F%2Flist1.auctions.yahoo.co.jp%2Fjp%2F%25E3%2583%2591%25E3%2583%25BC%25E3%2583%2584-%25E8%2587%25AA%25E5%258B%2595%25E8%25BB%258A-%25E3%2582%25AA%25E3%2583%25BC%25E3%2583%2588%25E3%2583%2590%25E3%2582%25A4%2F26322-category.html
Even if you decided to run your current injectors and ECU, you would still need to source the exhaust manifold, fit an intercooler, all the related intake piping, turbo dump pipe, probably a full exhaust. And there is no guarantee the engine would run well on DD injectors and ECU. There may also be issues with how many oxygen sensors the ECU monitors as well.
In summary, its not worth the hassle or the money. Should have thought about this before you bought the car. Some stageas have the VQ30DD and VQ25DD, theyre not identical to the Y34 engines but there should be enough info on SAU to give you some ideas of what mods you can do for performance.
Personally, I would do preventative maintenance on the car since you just got it (presumably from Japan). My car gained a lot from just changing spark plugs and coilpacks. A full exhaust system would be good, you could fit a shift kit, throw a Z33 LSD into the diff, inspect/clean the intake plenum because its going to be full of shit (theres a thread on SAU about cleaning the intake, but I cant find it)
https://www.sau.com.au/forums/topic/463595-vq30dd/#findComment-7697393
    • How do you propose I cable tie this: To something securely? Is it really just a case of finding a couple of holes and ziptying it there so it never goes flying or starts dangling around, more or less? Then run a 1/8 BSP Female to [hose adapter of choice?/AN?] and then the opposing fitting at the bush-into-oil-block end? being the hose-into-realistically likely a 1/8 BSP male) Is this going to provide any real benefit over using a stainless/steel 1/4 to 1/8 BSP reducing bush?
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
