Hello everyone
so i just got a Nissan Cedric Y34, and its got the VQ30DD engine in it, can i be enlightened with how i can turbocharge this engine (available turbo kits, hassle, etc) I am in Canada, and also id like to know how much this process should cost, how much power i can expect to get, etc :)
Edited by 4ventador
https://www.sau.com.au/forums/topic/463595-vq30dd/
Someone I know in New Zealand went through all this but his turbo kit was remains of a half-cut from a turbo Y34. There is no aftermarket turbo kit for Y34 (highly unlikely there would be one available in Japan).
The russians have a forum on Nissans that may be useful. http://forums.drom.ru/nissan-cedric-gloria-cima/
If you want to spend money on parts you'll have to browse endlessly on Yahoo Auctions. There are some nice bits second-hand you just have to be patient sometimes. http://translate.google.com/translate?hl=en&sl=auto&tl=en&u=http%3A%2F%2Flist1.auctions.yahoo.co.jp%2Fjp%2F%25E3%2583%2591%25E3%2583%25BC%25E3%2583%2584-%25E8%2587%25AA%25E5%258B%2595%25E8%25BB%258A-%25E3%2582%25AA%25E3%2583%25BC%25E3%2583%2588%25E3%2583%2590%25E3%2582%25A4%2F26322-category.html
Even if you decided to run your current injectors and ECU, you would still need to source the exhaust manifold, fit an intercooler, all the related intake piping, turbo dump pipe, probably a full exhaust. And there is no guarantee the engine would run well on DD injectors and ECU. There may also be issues with how many oxygen sensors the ECU monitors as well.
In summary, its not worth the hassle or the money. Should have thought about this before you bought the car. Some stageas have the VQ30DD and VQ25DD, theyre not identical to the Y34 engines but there should be enough info on SAU to give you some ideas of what mods you can do for performance.
Personally, I would do preventative maintenance on the car since you just got it (presumably from Japan). My car gained a lot from just changing spark plugs and coilpacks. A full exhaust system would be good, you could fit a shift kit, throw a Z33 LSD into the diff, inspect/clean the intake plenum because its going to be full of shit (theres a thread on SAU about cleaning the intake, but I cant find it)
https://www.sau.com.au/forums/topic/463595-vq30dd/#findComment-7697393
    • Not a problem at all Lithium, I appreciate your help regardless. I've pulled a small part of a log where the target pressure was 28psi and it spiked to 36.4psi. I've only just begun using Data Log Viewer so if I'm sending this in the wrong format let me know.
    • Sorry had a bit of a week and haven't had heaps of time to follow this, so apologies if I've missed something - any chance of showing a log with the rpm, turbo speed, MAP, and wgdc all in one view? Definitely an "interesting" problem, and while it's definitely worth noting that there was a similar issue with the twins I'd not completely put all bets on the root cause being the same thing.  Keep an open mind, follow the data.
    • I built this engine approximately 12 years ago so my own head (brain) is a little grey on the exact hardware in the RB head, however what I recall is. Stock RB25 NEO TURBO Intake Camshaft HKS 260 degree Exhaust Camshaft (R34 GTR) RB25 NEO Turbo Springs  I ported/removed the exhaust stud humps found in the RB25 head so theres less turbulence but it wasn't ported/polished properly, just a hump removal. I've attached two pictures of the before and after to illustrate.     The ECU gets its boost reference from the nipple on the rear of the head on the intake side, behind the fuel rail. The wastegate gets its boost reference from a nipple on the cooler pipe immediately after the comp cover.  Could a decent pressure drop across the intercooler cause the wastegate to be seeing a higher PSI than what the ECU is seeing, and thus it can't control it accurately and quick enough?   We ran a line to the actuator and watched it open and close using an air compressor, while we didn't have a gauge on the line to see when it was cracking open, it was opening smoothly.  I just removed the gate now and even though the documentation says you need to open it in a vice due to preload (which I did), there wasn't any preload on the cap, which is something we noticed straight out of the box as well when new. This silver cap internally is threaded to the actuator rod that runs out the bottom of the straightgate. Not sure how I'm supposed to get this spring out to be frank.. Potentially but everyone else doesn't appear to have to stop at 500kw because of 6boosts design.  I would, but I think I'm getting to that point where if I'm going to do the head and make another 100kw, then I'm going to need a fancy gearbox and quite a few other things and 10k becomes 20k becomes 30k within a few months. I'm not necessarily sold on the idea just yet that the head is restrictive at 4000rpm (and what.. 300kw?) and yet doesn't seem to be restrictive at 7000rpm when it's making 500kw, however I'm obviously not closing the door on that theory.
    • Yeah - Half the problem is I know this sensor actually goes to 150C.. I'm pretty certain it is min of 11C. So still more data required I suppose. It's really quite hard to get the oil temp to 100+ then immediately pull over and take a reading before the temp drops. Annoyingly I suppose the range I really 'want' is likely 80 -> 120C. TBH the ecu can't really *do* anything with it, and the gauge itself is very visible... ...but you know how it is.
    • My EFR 8474 Black, made 800awhp on a roller dyno. at 25-26psi. E85. Shaft speed was around 106,000rpm 1.01 rear. The rear is maxed.  6 boost Turbosmart 60mm gate 3.5inch exhaust  Head is worked to the shithouse. Bain racing. VCam. 272 exhaust. RB28 - RB26 foundation.  You have an intake issue. Start getting proper data and I mean go back to the simple things.  - Pressure test your intake - Block off the Turbo BOV, you don't need it.  - Test pressure before and after your intercooler If your head is pretty stock, that is your issue. Especially if it is NA.  Take it off and spend $10k on it.
