Hi guys.
Cam is located in Georges Hall. Shipping will be paid by the buyer as well as paypal fee's (if you want to use them)
Item: HKS Step 2 264 @ 10.0 mm exhaust cam to suit R32/R33 GTR.
Condition: Brand new. Original tape on the box. No need to take a photo of the stick, we all know what a camshaft looks like.
Price: $450
Reason for sale: Not needed. Came with my V cam and I am not pulling out my current exhaust stick.
2F58227B-B60B-4D9B-90E3-D7AB13FFAB0A_zps
Photo of part numbers.
801F9720-C42E-45C4-A269-54133832AF7F_zps
Photo of unopened box.
http://www.rhdjapan.com/hks-camshaft-step-2-nissan-rb26dett-exhaust-264.html
Link to product through RHD Japan.
SPECIFICATIONS:
Application: Exhaust Side
Base Circle (mm): 31
Duration: 264
Lift (mm): 10.0
Valve Timing: 113
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
