  • 3 weeks later...
As per the topic i have a brand new unopened Nissan S15 OEM tie rod end for sale
KMS want $77 plus post but i will sell it for $60 including shipping Aus wide or pickup is available on the northside of Brisbane
Cheers
Contact via pm thanks
Part number 48520-50Y25
Edited by Gts30t
  • 1 month later...
  • 1 month later...
For sale is my Apexi Power FC D-Jetro with EL hand controller and 2 x map sensors and wiring to suit BNR34.
The unit is in perfect condition and has only been used for about 25-30k kms. Comes with the newer and much better EL hand controller.
This D-Jetro model does away with the air flow meters and the cost involved with buying bigger ones such as Nismo or Z32 units :cool:
Price is $750
Itemis located on Brisbane northside for pickup or will post at buyers expense.
Oem center console, no lid, bit rough could do with a fresh coat of paint if picky $20
Oem stereo/ac/gearstick surround $20
Oem airbox snorkel, getting rare $50
Also RHS and LHS inner door handles available $20 for both
Accel pedal rubber and arm $10
Brake and clutch pedal rubbers $5 each
S15 OEM tie rod end for sale $50
Edited by Gts30t
Airbag sold!
Revised list
Apexi Power FC D-Jetro with EL hand controller and 2 x map sensors and wiring to suit BNR34. Perfect condition $675
blitz rb26 stainless front pipes, great condition $250
hpi clear rb26 cam gear cover, great condition $100
100 cell racing cat, suit bnr34, great condition $100
Cat sold
Revised list
Apexi Power FC D-Jetro with EL hand controller and 2 x map sensors and wiring to suit BNR34. Perfect condition $650
blitz rb26 stainless front pipes, great condition $225
Bump
blitz rb26 stainless front pipes, great condition FINAL PRICE DROP $200
Clear cam cover sold!
Apexi Power FC D-Jetro with EL hand controller and 2 x map sensors and wiring to suit BNR34. Perfect condition FINAL PRICE DROP $650
  • 2 months later...
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
