Generous offers only please
Item is listed elsewhere and may sell so get in quick
Genuine original Nismo Key 10 Point KEY01-RN010
This is genuine not a copy. Original box and Nismo logo design. Also look for the concave centre of the key which is a feature of the original Nismo key.
In excellent uncut condition
Getting very rare and hard to find in uncut condition
Was purchased in Japan 5 years ago
Designed for the following cars...
Skyline - R34 GTR - BNR34
Silvia - S15
Skyline - R34 GTT - ER34
I have also seen the 10 point keys cut and used on the following vehicles which require a 8 point key. I cant confirm it will work and suggest you talk to a locksmith prior to purchase.
Skyline - R33 GTS-t S2 - ECR33
Skyline - R33 GTS-t S1 - ECR33
Skyline - R32 GTR - BNR32
Skyline - R33 GTR - BCNR33
Silvia - PS13 (Red Top)
Silvia - S14 S1
Silvia - S14 S2
180SX - RPS13 S2 (Black Head)
180SX - RPS13 S1 (Red Head)
180SX - RPS13 S3 (Black Head)
Skyline - R32 GTS-t - HCR32
Skyline - R31 GTS-X - HR31
Skyline - R31 GTS-R - HR31
Would prefer cash on pickup from Carlton, Melbourne during business hours. Otherwise buyer pays for postage and postage insurance.
Let me know if you have any questions
Cheers
Simon
I'm pretty sure that will not fit ECR33 or the likes, the key blade dose not have shoulders so will be to thin.
I have seen the 10 point key used in the ECR33 before, both in pictures and physically in a ECR33 and S14 myself. To best describe how it was done; the key was cut on the end of the 10 point key meaning that they key sat further out of the lock or ignition than the normal 8 point key would. The shoulders (which connects the bow (handle) to the blade) of the key are the same thickness on a 8 point or 10 point key however neither of us a locksmiths and that's why i noted above that the buyer should contact a locksmith prior to purchase in my initial post.
Ive got both blades in front of me, you can cut it yes, but its not the correct key and wont fit the ignition proply . It says what it fits on the box with no mention of s14 or ecr33
I didn't say anywhere above that ECR33 or S14 was listed on the box? I have pictures of the box above which are legible and clearly readable. I didn't say anywhere that it is the correct key? I mentioned that I have seen a 10 point key working in a 8 point physically in an ECR33 and S14. You mentioned yes you can cut the key.
I clearly mentioned in the initial post that the potential buyer should speak with a locksmith prior to purchase as I cannot confirm the key will work.
If you already have both keys I suggest you speak with a experienced locksmith.
Please carefully reread the first post and if you have any further questions please PM me directly as your not adding any value to this thread besides increasing your own post count and reiterating what I have posted i my initial post.
  • 3 weeks later...
is the key still for sale? where does it fit the immobilizer chip?
Yep still available. No immobiliser on this key or any Nismo key that I know of unfortunately. I have heard that if you have the immobiliser key on the same keyring then you will be able to start the car and it will still read the chip from the original key but I can not confirm this so please speak to a knowledgeable locksmith to confirm this is possible.
Cheers!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
