I have bought a non runner r34 gtt and have spent the last 2 days trying to find out what the problem is.
The engine turned freely but would not fire so i started looking at the wiring, i went through every single wire, fuse and relay.
I now think i've found the problem, pin(s) 109,67,72,80 have no power.
Could someone tell me where fuse #33 and #34 are and also where the ECM and IGN relay is located
Any advice would be great.
Thanks
https://www.sau.com.au/forums/topic/464329-r34-gtt-wiring-woes/
Not sure if this will help you but mine had the same issue when I picked it up. Had lights, power to everything, would crank but not fire
Turned out to be a slightly dodgy connection at the positive battery terminal, between the terminal and the cable that runs to the fuse box
