I recently received my 350GT and want to upgrade the head unit to a double DIN unit. I saw that Metra facias aren't as nice as genuine Nissan ones. Can anyone confirm this is the correct part before I pay for it from japan?
https://www.japanparts.com/parts/detail/4353
I have the BOSE sound system without navigation.
Thanks!
I had a quick look for the part numbers but couldn't find them. The link I proivded does say "Including air conditioner, climate controller, dash pocket, blank bracket and bracket radio mounting", so I assume that's everything I need. The metra kits are close to $600 anyway, so I may aswell get the genuine part. I didn't buy this car because I'm concerned about money, haha.
  • 8 months later...
