thats at the wheels so 500 + from the fly wheel this is some one i know in japan an american over there.
he is running tome 2.2 pistons 264 cams ihi rx6 turbo,1.6bar boost and some otherthings. this car is capable of low 11's high 10's now he is looking for more going for the 2.4 kit.
hmmmm interesting.
meggala
so It can be done
https://www.sau.com.au/forums/topic/4648-486-hp-from-an-rb20/
