R33 Brembo Front brake calipers and rotors with pads.
Rear calipers off a r32 gtr (non brembo) with dba t3 disks, pads have still abit left in them. Everything In perfect workng order.
A little bit of water spilt on to the rotor will clear up as soon as they have been fitted
1200ono
Melb south east
  • 5 months later...
