I thought that there would be a tutorial on this but I just went looking and [although my search words could have been wrong] I couldn't find one.
If you reach down into the tank you will feel the long semi flat metal bracket that the pump is mounted on. Follow this back up to the top and you should also feel the clip. The bracket has a part of it bent in so that it clips into a locator as it slides into place. So you need to pull up on the bracket and at the same time pull the clip part out so that it unlocks. Once you've done one its easy .
Hope that helps. Pics might also help a bit, your looking at the back of the bracket here.
  • Like 2
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
