ADM Nissan 2001 200sx Type S
I'm looking to put my pride and joy up for sale. Had my fun and REALLY enjoyed the car for the 5.5 years I've had it. Trying to save some money and move to something a bit more basic (but still a little fun) to get around in.
I've spent alot of time researching and typically used the highest quality workmanship and parts available to me at the time. I'm very big on doing things once and doing them 'right'. I've also focussed hard on making the car as legal and 'stealth' as possible.
Car is my daily and has been the entire time I've owned it. I've set it up for daily/weekend/circuit/drift use. It's only done a Haunted Hills day as well as a handful of Motorkhana and Beginner drift days (Primal and Drift Skills).
Car runs and drive fantastically. Slightly laboured when it's super cold. 1min warmup and it's good to go. Always taken care of and treated with the mechanical respect she deserves. Service every 3-5000kms depending on time and events. Always used premium full synth oil (10/10ths or Motul). Fuel filter also changed every service.
Super responsive and very driveable setup. Full boost at 3600rpm. 'Only' running up to max 23 psi (tapers to 19psi) on e85, less on 98.
Car makes 271rwkw on e85 which is what I put in it 99% of the time. Had full flex setup and runs fine on 98 just less power / response.
Have a MASSIVE wad of receipts for pretty much everything I've ever purchased for the car.
Will come with Rego till April 2016 and a Roadworthy Certificate.
Exterior / Aesthetics:
Genuine Work Motion CR Kai wheels (18x8.5 front and 18x9.5 rear. Great fitment, legal-ish, no rubbing or scraping at all)
Vertex side skirts
Vertex rear bar
JDM fold in mirror
JDM seats
JDM dash
JDM badging on car
JDM steering wheel
Pioneer bluetooth headunit, quite new, works well.
Pioneer front split speakers
Amp and quality sub in boot (all in a custom sub box that sits in the 'shelf' to take up minimal space. Also has quick release mount, power, speaker cables. Can be removed in ~1min, SUPER handy for track days.)
Performance:
SR20DET rebuilt / forged ~15,000kms ago (Built by Forced Motorworx)
Forged pistons
Forged rods
New rings
ACL race bearings
Cometic head gasket
ARP head studs
Tomei Poncam (256)
Performance valve springs
Deustchwerks 950cc drop in injectors
Walbro 460lph e85 compatible fuel pump
Z32 AFM
Nistune compatible flex sensor
Nistune ecu with flex functionality
Garret GTX2863R
Kinugawa turbo actuator with 19psi spring
Earls Braided turbo lines
Standard airbox
Custom intake to turbo (black)
Havoc custom intercooler piping (legal, Blitz core)
Unknown 3" dump / front pipe (seems 'fine')
High flowing cat
Havoc cat back custom 3" exhaust (tucks up nice and high for legal reasons)
Handling:
Near new Yokohama AD08r tyres (235/40/18 front, 265/35/18 rear) - SUPER grippy!
Shockworks coilovers
SPL rear camber arms
Drivetrain:
Nismo 1.5 way GT Pro diff (4.11 ratio)
R33 GTS-T gearbox (excellent condition, uses Engineered to Slide kit)
NPC Heavy duty organic 10" RB25 clutch
Braking:
Slotted rear rotors and upgraded pads
Slotted front rotors and upgraded pads
I would be interested in trades plus cash my way but would have to be something interesting/fun/cheap for around 10k. Would consider something like:
 - e30 BMW (engine swapped?)
 - e36 BMW (engine swapped?)
 - VW Polo GTI
 - etc
NOT interested at all in anything like:
 - Auto
 - Skyline
 - Silvia
 - Supra
 - Commodore
 - Falcon
https://www.sau.com.au/forums/topic/466184-2001-adm-nissan-200sx-s15-type-s/
20 minutes ago, Birds said:
Price?
Whoops.
$25,000
Also forgot to mention car has installed and comes with the following:
 - Greddy eboost II prefec B boost controller (installed)
 - Tein strut brace (installed)
 - Whiteline front and rear sway bars (installed)
 - Standard exhaust (comes with)
 - 350z wheels with some Jinyu tyres. For track, drift, etc (comes with)
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
