Shockworks Presents Round 9 - Sandown Raceway 1st Oct | Grand Final Day
Sorry for the delay around lunchtime, here is a quick preview of some of the footage taken.
I will post up full link when it goes live tomorrow night at 6pm.
https://www.facebook.com/bezlife/videos/531345883738838/
Deffs why not. Haha.
Needed more skids. That last corner was sketchy all day. I remember coming around it crossed up many times and just having the tail out happy onto the straight hahaha.
