Nope. I have the 350z seats and didnt need one.
How?
Did the plugs match up?
I had to hard wire mine due to the differences in the plugs, even if they did plug together some lines were definitely different (two power wires on the seat plug, one on the car plug).
I have heard that M35s have two different types of seat plugs though.
Fuga seats look pretty good. I'm still not sure about going full leather again as found I was slipping around everywhere when I had them in my Legacy.
No idea how anyone lives with the stock fabric seats though...they are awful! Can't wait to replace them!!
I dont find this with the 350z leather seats as they hug body when in them. Not flat faced like most
  • Like 1
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
