Mongoose M80 Pre09 Issue!
Hi all,,
So I currently have an issue with my Mongoose M80 Pre 09 Alarm system on my 96 R33 Gts-t.
When I reconnected the battery (cars been sitting for a couple on months), all the functions worked per normal although it won't let my engine start. When I go to tic over, it sounds like the battery is flat (used 2 full charged battery's to check) with a ticking coming from the alarm box. The only way I can start my car is with a jumper connected to the battery.
I've turned the key of/on in the engine a bay alarm multiple times with no results.
Any suggestions, or others with the same issue?
Cheers
https://www.sau.com.au/forums/topic/467064-mongoose-m80-pre09-issue/
