R34gtr
Hello, I know this may be a long shot but is there anyone willing to let me be a passenger or even drive an r34gtr I have been saving for a while now but still have so much more to save. I have loved these cars and admire them and will be willing to pay. It's my dream to even sit and just be in one if anyone could help me out or know anyone who knows where I can just be with one it will be much appreciated.
https://www.sau.com.au/forums/topic/467504-r34gtr/
On 10/30/2016 at 7:23 AM, Danny95 said:
Thanks terry but no. I'm in the uk Cambridgeshire and dkb there's always that possibility but I want to be able to see what the car really has to offer and most places won't let you take it out unless you put a deposit on it.
I'll let you sit in the passenger seat of my R. You can pay for the flight to Sydney and the taxi here....
Why don't you ask on GTR UK forums? Might be better than trying an Australian based forum... Just sayin....
  • Like 3
https://www.sau.com.au/forums/topic/467504-r34gtr/#findComment-7787850
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
