FS: GTX3576 0.83a/r near new t3
great turbo for street or track. response same as n1 turbos but a lot more top end.
turbo only done 800kms include 2 hours dyno time.
rear housing is new t3 single entry.
price: 1600. include oil drain and water hose and fitting(used)
Edited by Nosure
https://www.sau.com.au/forums/topic/467855-fs-gtx3576-083ar-near-new-t3/
1 hour ago, Darmanin10 said:
Was it on an rb26?
how much power did it make?
yes made 480hp on 20psi e85, same or better response than stock n1s, but my n1 only made about 380hp on 18psi.(same low read dyno) i actually make the boost come up slow to avoid boost spike.
  • Like 1
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
