IHI C7 (TD07 equivalent)
I have an IHI C7 turbo for sale.
I ran this turbo on my SR20 200sx, it made 450rwhp on 25psi on pump 98 fuel on the PITS dyno and the car backed it up with 133mph trap speeds at Willowbank
It has a ~66mm inducer on the compressor and the back wheel measures around the same. Started spooling on my SR20 with big cams and 8.5:1 comp at around 3000rpm and full boost just after 4700rpm. Perfect for an RB25/30 with E85. There is minimal shaft movement up and down, no shaft movement "in and out" Has a few tiny chips on the inducer blades as can be seen, which is to be expected for a used turbo.
Comes with the adaptor for the rear housing to take a 3" dump pipe, has a T4 flange.
Price is 500ono, located on the north side of Brisbane.
Please phone or text 0415 952 006 as I don't frequent the forums that often. I have sold my car, but kept this turbo as I was planning to build a RB of some description, but I've lost interest so I'm letting it go.
Cheers,
Ahmed
https://www.sau.com.au/forums/topic/467996-ihi-c7-td07-equivalent/
  • 4 weeks later...
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
