#3837 INNOVATE MOTORSPORTS LM-2 Wideband AFR Meter "Basic" Kit
As title says, Brand New still in box and packaging.
Bought 1 month ago, but sold car recently.
Have no use for it.
Paid $450
Selling for $340.00 delivered anywhere in Aus
The Innovate LM-2 combines an air/fuel ratio meter, a full-function 32-channel datalogger, and powerful software to deliver a complete tuning workshop for less than the cost of one dyno day. Whether you have a piggy-back fuel controller, race carb, aftermarket ECU, ODB-II tuning software, or a flash/chip programmer, an LM-2 is the tool you need to dial in maximum HP. The meter’s award-winningdigital signal processing technology provides data on exactly how rich or lean an engine is running at any load.The LM-2’s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition.
Patented “Direct Digital” Wideband Technology
Wideband O2 Compatible with ALL fuel types
Single or Dual Channel Version Available
OBD-II Scan tool- read/clear DTCs and log up to 16 channels of CAN OBD-II Data
Log directly to SD card (included)
Playback log data on screen and/or with powerful LogWorks software (included)
Large high-contrast graphics LCD
Built-in RPM converter (direct frequency or with optional inductive clamp)
4 fully-differential analog inputs
2 configurable linear analog outputs
Positive lock connectors for all connections
Innovate MTS serial IN and OUT
USB connection to your PC
  • 1 month later...
AEM Gauges for sale - BRAND NEW
So I have a few BRAND NEW (still sealed in the box, never opened) AEM gauges that I have left over from my build, and have recently sold the car. Now no need for them.
AEM #30-4110 UEGO Digital Wideband Air / Fuel Gauge kit - $270
AEM #30-4407 DIGITAL DISPLAY OIL PRESSURE GAUGE 150 PSI - $250
AEM #30-4402 DIGITAL DISPLAY WATER TEMP GAUGE 300F - $200
AEM #30-4350 DIGITAL TRU-BOOST Controller - $375
Will sell individually or happy to do a package price for all 4 - $1000 neat
Well under RRP for these great gauges.
Located Brisbane, pickup available or happy to post interstate.
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
