For sale rb25-30 external oil pump set up
All is needed is a 20mm x 576mm 8m belt and ross balancer to suit wat u have got $2900ono.
Does not include Balancer
Was fitted to a r32 with rb2530 .
Selling due to changing to dry sump
$2900
Penrith.sydney west nsw
Any other questions just ask
0422720640
Wat u see i the pic is wat u get
Also selling a rb25 high mount turbo manifold.(i made myself) T3 flange
No cracks,ceramic coated
With genuine turbosmart 50mm wastegate and stainless steel sreamer pipe
Both items are 2yrs old
Was in are r32 gtst
$1000 20170205_132512.thumb.jpeg.58bce44080170
R32 oil catch can (i made myself)
U need to relocate the fuse box
Has 2off -12an fittings and a 32mm dia k&n filter for breather $250
I can well a -10 return drain to the sump if needed
1486262489119.thumb.jpeg.81fcb3d67d03ea6IMG_20160620_192309.jpeg.8af31c77158b66b
  • 3 months later...
  • 1 month later...
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
