FS: New 1000hp fuel setup. Top brand. And aeroflow fittings
1. New Magnafuel pump mp4303 (good for 750hp e85 single pump continue duty. Flow about 500lph at 70psi) $600,new filter suit the pump: $70
2. New Radium High volume external pump surge tank. $600
3. New JMS FUELMAX single pm2000 40A (boost up voltage from 14v-20v adjustable and ramp in function, active when boost or 5v, much better than kennebell bap) $500
4. Used SARD fuel reg good condition with fittings. $100
5. New Aeroflow Kevlar braided teflon hose -6an 4.5m  $220
6. New black hard line 1/2 (12.7mm) $50
7. New aeroflow 400 blue hose -6 an (3/8) 3m. $50
8. A lot New aeroflow fittings (an 6 8 10 12 full flow push on hose end, 8 orb-6 8 10an fittings efi fittings, 5/16,1/2 hard line fittings) want sale as a package.  From $100
9. Tomei type A valve springs for rb26 (only test fit. $100
If buy pump, surge tank and fuelmax bap together. I can do a better deal. Or give you the fittings you need for install. And this is 1000hp e85 combination on single pump. One pump= less heat less worries.
I change my mind, so no need these parts. They all genuine.
Fs: Id 1300cc e85 11mm rb26
Less than 600kms. Perfect condition.
still on my car, if someone want them I will remove them after 13.02.2017
price:1000
Locate: gold coast
I don't have enough money for id1700 so I might keep my id1300. (  If I want sale it again I will post up.
unless someone want buy my surge tank setup then I can sale the injectors.
A lot parts still for sale.
4. Near new turbosmart 1200 v2 fuel reg good condition with fittings and gauge. $120
5. A lot New aeroflow fittings (an 6 8 10 12 full flow push on hose end, 8 orb-6 8 10an fittings efi fittings, 5/16,1/2 hard line fittings) want sale as a package. From $100-500.
6. Id1300x e85 injectors 11mm rail. (Can be fit on different rail with different hats) only done 2 dyno run. $1000. Paid 1700
6. Tomei type A valve springs for r34gtr (only test fit. $100
  • 3 weeks later...
Update
1 New Radium High volume external pump surge tank. $600
2. New JMS FUELMAX single pm2000 40A (boost up voltage from 14v-20v adjustable and ramp in function, active when boost or 5v, much better than kennebell bap) $500
3. Aeroflow push lock fitting from 6an to 12an. Enough build one whole car fuel system with surge tank. And a lot other fittings ( orb fitting, hard line fittings, npt fittings)
4. Tomei type A valve springs for rb26 (only test fit. $80
5. R34 gtr cas used  good condition $180
6. New turbosmart 1200 fuel reg v2 ( waiting turbosmart send back). $200
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
