1997 R33 gtst s2 for sale in Brisbane
1997 GTST for sale, located in brisbane
Well it looks like I may be selling my white R33 GTST. It currently has 116k on the clock. I was the first owner in Australia and have had it since 2007, it had 40k on the clock when I bought it. The car is in really good condition with a fair few mods. Im looking to get $16 000. I will be taking it today for a nice wash and have a few things from my list to finish off that are half done before taking any pictures but am hoping to find someone who is interested in it now. The car has a flex fuel and gets just under 310kw on e85 and 290kw on 98 with a pretty safe tune. I spoke with my mechanic and he doesnt see any reason why it wouldnt pass a RWC and I'll be getting that done as soon as I can. I honestly wouldnt be selling it except for the fact I need a 4 door. Possibly interested in trades + cash either to or from me depending on the car.
Mods:
New tires this year
18" wheels, wider wheels on the back with 275 tires
Full turbo back exhaust
Jim barry clutch
FMIC
Vipec ecu
td06 turbo 2 years ago
1100cc id injectors with fuel rail
highflow fuel pump
upgraded fuel reg
coilovers - set to legal height
reconditioned radiator 2 years ago
reconditioned exhaust manifold 2 years ago
all suspension bushings changed last year
gps locating alarm
Clarion fold out head unit with polk speakers all around (I have 2 12s in the boot in custom fibreglass enclosures, the enclosures need some love as I didnt get the carpeted and havent sorted them out to paint but may keep the subs/amp and include the enclosures only)
Meerkat boost gauge pod with HKS boost gauge
Nismo speedo (came with the car new but when the tack started bouncing I changed the rest of it to a GTR and swapped the nismo speedo in)
I have a spare rear ganish that lights up and is all ready to be put in, just havent got around to it
The bad:
Wheels need a spray as the shadow chrome is peeling and there is a little gutter rash (that was there when I bought the wheels)
Clearcoat is coming off
small chip in the front indicator surround (someone backed into me with a towball and took off)
Needs a tune (it stall from time to time when the RPMs drop, coming to a red light for example)
Drivers seat is showing a little wear
If interested please give me a call or text 0416 627 645 and I'll get some photos up as soon as I can. Hard when you got 2 under 2 lol
Anyone interested before i put it up on carsales? Would take 14.5k as it is. Spoke with my mechanic and he reckons it wont need anything for rwc but you may need to borrow a stock airbox
Ive got a 4 door lined up. Will sell this unregistered this weekend for 13.5K, I have it booked in for a service/tune/RWC on Monday but would rather avoid the cost/hastle... I have receipts for most of the work done. Someone must be looking for a r33 in decent condition! Come Monday it'll but up on carsalses but will have to add in what it will cost for the work
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
