Help! How to Late BNR32 Cluster in pre 91/8 car
Hello i need some help. Does anyone have a full write up how to get a +91/8 Cluster to work in a pre 91/8 BNR32. I know how to do the speedo, i found that info on this forum. Problem is that i can't find a writeup on how to fit the rev counter. I know that it has been done, just now how.
Any help is welcome.
