Kebabs and Cars, 29 April 2017 @1730, Nandos Vic Park, Cruise to the Meet
Haha, Hey im Bianca im new on here i have a R33 s2 I've had my car for 10years [emoji23][emoji23] time to show her some love .
Bianca !!!! Omg omg omg ! lady friend here !!! Yay !!!!
Im Elle [emoji7] married with 3 fur babies, where about do you live and are you coming to the next cars and kebab ?
Most of us talk in wasteland - so jump in there !
x
  • Like 2
Hahaha!! Girl power. [emoji23][emoji23] I live in Gidgegannup so far away! When's the next kebab? I'll jump on wasteland and check it out.
The next one is on this coming Saturday , you're on the right page for the event details [emoji14] check it out girl [emoji12] wasteland is where we talk about everything in general [emoji41]
Oh where is Gidgegannup ?
Sorry, the group is Perth 33's. [emoji4]. Although I'm quite sure they wouldn't mind a 35 there. I can ask if you are keen
Only if 32's , 34's can come along [emoji14]@shoey85
  • Like 1
I'm near Stoneville Road. I can't make this Saturday I'm working [emoji17], awseome I'll check it out [emoji3]
  • Like 1
Is that near mundaring ? [emoji33][emoji33][emoji33]
Are you going this cars and kebab meet Justin? Starts at 7pm
Bianca what time are you finishing work ? Share some
Picture of your car on wasteland [emoji1]
Undecided at this moment.
  • Like 1
2 hours ago, ElleAli76 said:
Come along - we haven't see you for ages !
I spend the majority of my time at that building, it's just hard to convince me to go back there after work.
4 minutes ago, CR33D said:
if you're on a desktop, you can drag and drop, if you're on a mobile browser, there's a paper-clip button, and if you're on the Sauwa app I think it's also a paperclip button.
  • Like 1
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
