i will keep a look out for further updates i am interested in them it sounds like a worthwhile alternative to getting 550cc injectors.I am not after more than 250rwkw and im guessing with an increase in rail pressure they can be pushed closer to 500cc.
Are they a straight swap injector?
https://www.sau.com.au/forums/topic/47058-bigger-injectors/#findComment-952620
coming from the sr community, i can tell you there are a quite few people pushing there s15 turbos and injectors to around 200-210rwkw with some extra fuel rail pressure
and there pretty maxed out at around 190rwkw with stock fuel rail pressure..
so if you have 6 of then i would imagine something like 200/4 x6= 300rwkw would be possible with extra fuel rail pressure
there is someone on silviansw.com selling a set of 4 for $300 for anyone interested too :D
https://www.sau.com.au/forums/topic/47058-bigger-injectors/#findComment-953643
I am currently converting my rb30 to turbo power and ive read that the vl injectors run out of steam pretty early in the piece. I have also heard that R33 GTR 444cc injectors may well fit straight in. If anybody knows it would be a big help. May as well buy the GTR injectors instead of the Holden variety if they fit.
https://www.sau.com.au/forums/topic/47058-bigger-injectors/#findComment-953655
Simple numbers guys, 480 cc's in a 6 cylinder engine = ~480 bhp.
So 480 bhp / 1.34 = 358 kw
Less say ~65 kw for drivetrain losses = 293 rwkw.
That's at standard fuel pressure, whatever that is for an S15. Knowing Nissan, probably ~38 psi above boost.
Hope that helps :)
https://www.sau.com.au/forums/topic/47058-bigger-injectors/#findComment-954758
GTR's are top feed low impendence.
You'd need the resistor pack also and probably a custom/GTR fuel rail (?)
https://www.sau.com.au/forums/topic/47058-bigger-injectors/#findComment-954777
Check out http://www.calaisturbo.com.au/index.php
https://www.sau.com.au/forums/topic/47058-bigger-injectors/#findComment-954840
I believe that late ( '96 and later) model 300zx VG30 uses injectors that will fit a RB25.
no responcability accepted for accuracy of information in the previous sentance so don't come running to me when your pistons are a melted pool of slag in your sump... :-)
https://www.sau.com.au/forums/topic/47058-bigger-injectors/#findComment-955846
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
