Hey guys,
Im having no luck locating a 32/33 turbo coolant line so i am resorting to other measures.
I have the banjo bolt itself but not the hose, I was wondering if i can get the fitting which the bolt goes inside of and just run some rubber line with a hose clamp on it to the coolant outlet on the heaters (stock position).
Basically get a fitting similar to the one I have attached (except this is a NICS coolant line) and then just some coolant hose instead of a metal one, and then just attach with hose clamps.
If so where can I get such a fitting? Pirtek or Enzed?
Is this a wise move or should I go for the 33/32 line instead?
Thanks
https://www.sau.com.au/forums/topic/47077-turbo-banjo-bolts/
Hey 200zRRR,
If you end up going the braided route I will take the banjo bolts off your hands.
I'm in the opposite boat at the moment, have the lines but no banjo bolts.
I was going to get them from Nissan when I get the turbo gaskets, but if you don't need them i'm keen.
https://www.sau.com.au/forums/topic/47077-turbo-banjo-bolts/#findComment-956988
