32 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
this is funny, cos i was at a friends yesterday and we noticed a mamoth yellow thing sticking out of his next door neighbours garage, so we walked over.. hes doing exacly that, has a worked lexus V8 engine, porsche box, and heaps of other bits and pieces. Hes making it from scratch. Should be done by christmas, cost around $100k all up, and hes planning on entering targa tasmania.
Im not positive, but its going to be street registered etc etc
It looks fairly crazy, hes doing everything in order to race it professionally.
Hes running 335s on the back! Has 2 engines he will sway between, one is a worked lexus V8 the other some kind of twin turbo, i forgot to ask what it was.
A brand new Lamborghini is about $300,000k
It isn't lame, its a good idea and you can be proud to say "I built this car" really, and if it dosen't have the 5.7L V12 Motor in it it still dosen't matter, a V8 would be better for daily driving anyway.
i think youll get more laughs out of people when they see what looks like a lambo driving past and sounds like a lexus driving past, if you dont have a diablo motor in it dont waste your time, i would kill myself laughing if i saw someone driving in one, and then i would blow past them in my car and laugh.
most serious lambo kit builders use a big block chevy in their Pontiac Fiero (ideal platform since its a Mid engine base). I think you'll find it very hard to keep up with them seeing that they are based on such a light base with a FULL fibreglass body, as opposed to your full metal body and rolling stock. My mate owns a silver Diablo replica in the UK (he went to the extreme of using a honeycomb aluminium tube chassis and chevy engine). If you can blow past him I'll be quite impressed (yes I know you own JETT :rolleyes:).
hahhha i almost missed that last part where you wrote " yes i know you own jett" but even jett might not be able to keep up
the fact that he's an aeronautical engineer for boeing helped too since he made his own chassis tubing... he's a complete nutter.
But you're average joe will get laughed at, true.
For those just looking to stun instead of imitate, there's a supercar kit available which is made from a Honda Accord engine and other parts, and the suspension setup from a Lotus Elise etc etc.
www.kitcars.com is your friend :rolleyes:
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
