  • Replies 123
Looks like you could have a good turn out George,,,,,Count us in,,,We'll bring the Mascot....
Shell if you get in to Sydney early,,,drop me a line
0419 160561,,,we're on Holidays,,,could meet up with you and George,,,do some arvo coffee/food or something.
Neil.
yeah looking good neil. can't wait to see your horse... i mean monty again. i've taken the day off & i have to go pick up ryan around lunch time so i'll be around pretty much all day. i'm up for anything so...
hey, i told you i'm changing sides. st george is a sad team these days. good win over the broncos though.
Everyone, if you can't meet at the right time or get lost or whatever, my number is 0438 438 567
George
Neil.
Will do, Neil! ;)
I doubt it will be before about 4pm tho, cos I'm not planning on leaving here till around lunchtime.
NDR Wrote :
Hey ONARUN,,,I'll let you in a little secret,,,,when you get Married ,,,She becomes the BOSS. It's not a bad thing,,,just as long as YOU have trained her well.
Thats what I call hitting the nail on the head, so true, so true.
