Well ive had some issues getting the rims i want for my car. Its a GTR R33, i put an order in with Buddy Club for some QFs 18 X 10 but they stuffed it up and i'm looking at up to a 14 week wait!
So now I'm after some brand new or brand new quality rims at least 18 X 9 with standard GTR offset (around 30 i think). Looking at spending up to $4G. If anyone can help me out please let me know.
Thanks
https://www.sau.com.au/forums/topic/47239-wtb-gtr-r33-18-rims/
Dave,
Primary choise is Buddy Club QFs in gunmetal grey 18 X 10. Trouble was Buddy club have stuffed up the order twice, issues with the mould or some crap, anyhow they quoted me 8 weeks to make plus 6 weeks to send. Let me know what you can do. As it stands i'm happy to wait and see if anything else comes along.
Thanks
Hi there,
I have a set of R34 GTR genuine rims in very good condition for sale. I'm after $3300 ono no tyres, can arrange tyres. If interested please pm me.
Regards,
stav
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
