Hi all,
Got a bit of an issue with my V35 manual coupe.
Wondering if anyone has any ideas what could be causing the sound in attached video?
  • Happens when decelerating from anything over 80km/h
  • Steering wheel will shake sometimes, other times it doesn't.
  • The noise is present without braking
  • Wheels and tyres are fine - IMPUL F919S with new Federal 595RSRs
  • Noise appears to be coming from drivers front wheel area
  • Calipers are not stuck
I've put the car up in the air and can't find anything visually wrong underneath. Spun the wheels by hand, sounds normal.
Was hoping it would be a wheel bearing, but now I'm not so sure.
Any ideas?
received_1749827491756552.mp4
Edited by nicholascleef
have you checked for loose plastic inner guard covers, sounds like something slapping around in there, maybe some of the plastic clips have broken?
Other than that, possibly bad bushes.  Does the noise go away if you apply brakes?
The noise doesn't go away if I apply brakes, nor if I put the clutch in. Inner guards etc are all secure and as normal. The noise only goes away once the vehicle has slowed down to below 80km/h regardless of whether I apply the brakes or just let the car gradually slow down.
Has brand new rotors and pads. Clutch is brand new too - Exedy heavy duty, single mass flywheel conversion.
Front lower arm bushes and lower ball joints replaced also. All this work was done less than 5,000km ago, car has been driving fine until recently.
Noise started occurring when I was giving it the beans, so I've obviously damaged something.
I know you said the guards are secure but plus one on sounding like loose plastic.
I had an issue awhile ago where one of the smaller plastic covers that links to the undertray was loose.
Wind would hit it at certain speed, get partially trapped and would make noise.
hmm.. if it was bushes, I would expected to have seen some change with brakes, possibly steering linkages, but I would think that would be more obvious.
I know you checked, but the only thing I can think of that lines up with the symptoms well is a loose splash guard or fender liner.
Giving it a boot full of throttle shouldn't have broken anything in the front suspension, it is just there to steer and brake.
Thanks everyone for the responses. The noise ended up being the under tray, some of the clips were broken, hence it was partially loose. Not sure how I didn't notice this the first time I had the car up on the hoist. Obviously it was catching the wind at 80km/h+.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
