Cheers ladies and gents. My name is Abel, 29 years old male (despite the display name, i'm a guy...) And currently living in the Netherlands. I've always had a thing for Skylines and Stageas also had my attention for a while. Bought a Stagea (which i named Stacey, hence the display name) last june and been enjoying every kilometer so far! I've been browsing around for a while already and decided to finally join. Hoping to learn heaps and to meet awesome like-minded folks here :)
https://www.sau.com.au/forums/topic/473368-new-guy-on-the-block/
10 hours ago, PranK said:
Welcome to SAU! :welcome:
Stag looks nice and clean, well done! I can't imagine there'd be many there?
Hey thanks!
Yeah she's completely stock, aside from a turbo timer and the 350gt alloys. i believe there's about 10 or 11 of these wagons country wide, and 3 or 4 of which are for sale.
