Hi everyone ,
im looking to purchase a r32 gtr but it seems to have a bent chassis rail , is it worth fixing with confidence it can handle power up to 450hp? Or will it be fragile and more likely to break or bend again ?
Thankyou
I was looking at an R32 non GT-R once that had crushed rails. I took a bunch of photos and walked into a workshop, they basically laughed me out. A proper repair will be costly - given that it's a GT-R it may be worth it, or may not be. It will never pass roady unless repaired correctly. I'm not liking all that rust around the lift point either.
If I saw that on a car I'd be wondering what happened, why it hasn't been repaired, and what else is wrong. Do a paint thickness check all around at a minimum to see if it's been partially resprayed and/or bogged up, and maybe check alignment if you can for an indication of whether the chassis is true or not.
Thanks a ton for this response , the car has had a respray and the owner has had the car with this problem since day dot he says , I have been quoted $1500 to repair it , how would I go about the allinment and getting an accurate reading ?
  • Like 1
The rail's not bent.  It's just f**ked.  Classic moron jacking it up wrong and/or bashing it into speedbumps.  It is major league defectable.  It is very fixable, but at a cost of course.  On my R32 we made a tool that we could insert through the holes in the rail to push out the (much smaller) damage done over the years before I had to take it through Regency for approvals because we know they are (unts about that sort of thing.  If they saw that photo, they would hand you a defect notice to stick on your head!
Edited by GTSBoy
Once fixed should I be worry that the chassis not being able to handle power mods ? Or is this just a stay away from the car and that’s that ?
You could fix that rail so it is 3x stronger than original.  I make no representation as to what state the rest of the car will be in if the rails look like that though.  That is a sure sign of "give no f**k".
  • Like 2
^ What he said.
Given that 32 R's are getting pretty old and increasingly rare, if it looks like you're getting too good a deal, you probably are.
Good examples are hard to find, you just gotta do the work and have the $$ ready.
At the current prices I would have a mile long checklist and inspect the car several times in good daylight plus have a workshop go over it in detail. The alternative is to buy the 20k 'immaculate' one and spend another 20k+ fixing it - an option for sure, but tedious.
^ What he said.
Yeah I understand I’ll probably stay away from it for the meantime and check out clean ones for the extra dollar [emoji1362] cheers
  • Like 1
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
