Blitz r33 gtst ecu - $50
Apexi safc & Apexi sitc - $150
Stock 21u r33 turbo - $100
Stock r33 s1 maf - $30
Stock fuel rail and injectors - $30
Pickup from seven hills 2147.
https://www.sau.com.au/forums/topic/473514-stock-rb25-parts/
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
