Rare 18" Veilside Andrew Racing Rims
5X114.3
9" Fronts 245 40Z R18 Nexen N3000 75% tread +34 Offset
10" Rears 265 35Z R18 Achilles Atr Sport 2 tyres  Brand new driven less then 100kms +45 Offset
Reason for sale, i have sold my car after a melted piston incident.
I personally imported these from yahoo japan for $2200 in 2014
The rears have some minor rash around the rim , the fronts are perfect.
Clear coat has been removed from the rims and they are polished Raw alluminium, very easy to keep clean that way
Always got alot of comments on the rims.
no buckles, perfectly balanced, all centre caps included.
They were mounted on my 300zx, but will fit other imports aswell
If you are seriously interested and have Cash please contact me and we can arrange a time for viewing , i wont accept partial payments, weekly installments etc.
Contact via phone, sms, message , email and ill get back to you when im available
$1400
Located Perth,
Leeming south of the River
Will fit r32 gtr , r32 gtst, s15 etc and other imports
Edited by srimes101
Spelling
https://www.sau.com.au/forums/topic/473726-18-veilside-andrew-racing-rims/
  • 3 weeks later...
  • 2 months later...
  • 4 weeks later...
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
