2003mdl Autech Axis 209KW AWD 2.5lt turbo 145 000km . Very good condition for age. Some minor Knicks and scratches, nothing big.
Totally stock standard except for front brakes which have been upgraded to r34 gtt 4 pot callipers and 310mm discs, intima sr front pads and remsa rear pads. Will also come with standard brakes if you want them. Also fitted with roof rack and alarm/immobilizer.
Turbo was replaced at 135k km with a low km (65000) standard unit, oil feed was upgraded to a braided one at the same time. Plenty more life in this turbo.
Autech cream leather interior with heated front seats. Ac climate control works beautifully. Has aftermarket Android 5.1 head unit, cd/dvd/nav/obd reader system with 2017 navteq maps and hobdrive obd software connected to factory bose sound system.
Spark plugs and diff/transmission fluids replaced at 120k and wont need to be done again till at least 200k. Coolant done at 140k. Engine Oil and filter will also be replaced prior to sale. I have serviced this car personally and oil has been replaced every 5k km using penrite synthetic. This car has been well looked after and has plenty of life left in it. Myself and previous owner are both sau members who have treated this m35 well.
The only negatives are rear split window in the tailgate doesn't open (possibly the switch), rear tailgate struts need regass or replace. A squeeky bush in the front suspension (only in really cold weather)
Reg till 31/10/18 $6200 as is or $6800 with RWC. Located in s.e suburbs of Melbourne.
These are old pics but still looks the same. Will update with current pics when i get some time.
https://www.sau.com.au/forums/topic/474744-m35-stagea-autech-axis/
  • 4 months later...
Back up for sale. Now has reg till 31/10/19. Price is now $6500 with reg and plates, no rwc. 146 700km on the clock. Has just been detailed and will gave fresh engine oil and filter. I will also include a few spare oil filters i have.
Some current pics.
IMG20190119200207.jpegIMG20190119200004.jpegIMG20190119200137.jpegIMG20190119200105.jpegIMG20190119200353.jpegIMG20190119200506.jpegIMG20190119200909.jpegIMG20190119200926.jpegIMG20190119200951.jpegIMG20190119200902.jpegIMG20190119200729.jpegIMG20190119201005.jpegIMG20190119201235.jpegIMG20190119200547.jpegIMG20190119200739.jpegIMG20190119200825.jpegIMG20190119200804.jpegIMG20190119201404.jpegIMG20190119201409.jpegIMG20190119201431.jpegIMG20190119200531.jpeg
Bump. Just serviced, fresh oil and filter. Will come with 4 new oil filters and a new set of front brake pads for the r34 callipers. Will also come with stock m35 front brake setup.
Price dropped to $6000 with reg or $5500 without reg for anyone interested from interstate. Great reliable car, come and get a bargain.
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
