T0nyGTSt Posted July 29, 2004 Share Posted July 29, 2004 Is this a good idea? I know why it would be a useful. Is the auto still LSD? Will fuel consumption suffer? T. Link to comment https://www.sau.com.au/forums/topic/47493-automatic-431-diff-instead-of-a-stock-4111/ Share on other sites More sharing options...
FATGTS-R Posted July 29, 2004 Share Posted July 29, 2004 I would assume the auto diff is LSD, but dont rely on that. Fuel consumption I imagine will increase on the highway at a minimum. As you will be at a higher rpm to sit on 100km/h than with the 4.11. I have a 4.33 in my R31 and it sits just under 3,000rpm to do 100km/h. Also understand that your speedo calibration will end up being incorrect. The speedo reading will be higher than your actual road speed. But if you have aftermarket rims that have a overall bigger diameter than the stock rims they might cancel each other out and the speedo might be very close. Just get it checked next time you are on a dyno. Link to comment https://www.sau.com.au/forums/topic/47493-automatic-431-diff-instead-of-a-stock-4111/#findComment-959918 Share on other sites More sharing options...
Abo Bob Posted August 2, 2004 Share Posted August 2, 2004 I don't know about 33's and 32's but in the 34 the auto diff is a viscous LSD and the manual is a helical LSD. The ratios are both difference too I think. Link to comment https://www.sau.com.au/forums/topic/47493-automatic-431-diff-instead-of-a-stock-4111/#findComment-963219 Share on other sites More sharing options...
Fly_With_Sky Posted August 2, 2004 Share Posted August 2, 2004 im pretty sure the r33 autos have a viscous lsd also (not sure bout 32). the rpms in auto r33's from my experience sit on about 3 000rpms at 120km/h Link to comment https://www.sau.com.au/forums/topic/47493-automatic-431-diff-instead-of-a-stock-4111/#findComment-964658 Share on other sites More sharing options...
knore Posted August 3, 2004 Share Posted August 3, 2004 yeh its LSD in auto 33s too Link to comment https://www.sau.com.au/forums/topic/47493-automatic-431-diff-instead-of-a-stock-4111/#findComment-965073 Share on other sites More sharing options...
WazR32GTSt Posted August 3, 2004 Share Posted August 3, 2004 and its an LSD in the auto R32GTSt as well... Link to comment https://www.sau.com.au/forums/topic/47493-automatic-431-diff-instead-of-a-stock-4111/#findComment-965232 Share on other sites More sharing options...
SS8_Gohan Posted August 4, 2004 Share Posted August 4, 2004 I don't know about 33's and 32's but in the 34 the auto diff is a viscous LSD and the manual is a helical LSD. The ratios are both difference too I think. For manual R34's, between Series 1 and 2, the LSD changed. And i can never remember which way I think it went from Viscous in Series 1 to Helical in Series 2. I've got a 50/50 chance cheers. Link to comment https://www.sau.com.au/forums/topic/47493-automatic-431-diff-instead-of-a-stock-4111/#findComment-966853 Share on other sites More sharing options...
