I have some 270/10.8 cams and want to adv the IN and retard the EX to improve lower down torque/boost.
Have a standard head (some port work) but not skimmed and running a 1mm HG. Pistons not recessed.
Just wondering if anyone else has advanced a similar cam with thin HGs in regards to PV clearance.
Normally min is 2mm inlet and 2.5mm exhaust.
Searched but could not find anything related to PV clearance.
Engine is in the car and do not want to pull the head off, heard people using bluetack on a cable tie with a drop of oil on it
Anyone's real experience and info on this would be great !
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
