Im looking at buying an after market blow off valve cos i love the sound. Now seeing as the RB26's have 2 from the factory, would one still do the job?
The reason I ask is I have seen an r34 gtr with only one HKS blow off valve:
http://www.xspeed.com.au/ssport/04r34/04r34gtrbov.jpg
Will this be alright with any sort of blow off valve?
https://www.sau.com.au/forums/topic/4761-aftermarket-bov-for-rb26-help/
The only one that can stand up to the job (Well there is prob others!)....The Greedy type-R BOV. This puppy is huge! Approx $600
I had 2x Turbosmart's on mine....But I have just put the factory ones back on, as the T/S's vented into the atmo, and made the car run like sh1t! idled like crap, stalled at the lights, fluctuated through gear changes,and ran the car rich/lean!
Factory ones are good for 600 odd horses....No need to change!
Unless you have an after market computer that you can get rid of the AFM's, and run atmo BOV's ....Stick with the factory Pssss makers!
CV
Guest Nismo_Freak
Alrighty ... where to begin! First off that Pshh shhs shsh shh noise you heard was from the valve not opening all the way cause of either two things, a. shifted before acchieving enough boost to open the valve or b. valve is not adjusted properly. Notice the placement of that valve. Its after the intercooler when it changes into a single pipe. Which is an ok place to put it.
Sounds & Quality:
Blitz's unit makes either a quiet Psssssssss or a louder Pssssssss depending on weither or not you used the horn. The Blitz unit as expected is very high quality but not the loudest on earth.
HKS's SSQV unit makes a loud and sharp noise. Its a very good BOV as well. Often alot cheaper than the Blitz units. Only way I can explain it is a loud Chirrr!
HKS's Racing BOV, unit makes different noises depending on boost. It varies from the SSQV to the Blitz unit. Its a high boost only BOV.
GReddy Type-S, if you've seen the fast and the furious thats the BOV noise they used. It sounds similar to a balloon when you let the air out but in a quick burst of sound. Its not ment to run in high boost setups so if you run more than 1 bar get the Type-R.
GReddy Type-R, its the racing BOV used in high boost setups. GReddy recommends that you run around 14.5psi (1 bar) or more to effectively use the valve, it has a hard spring. It makes a sound similar to Type-S but with more of a Psssss noise created by the Blitz. Its a well adapted BOV for high boost.
Apex'i BOV, this is a general BOV. It has good response and sounds pretty boring but it gets the job done effectively. It sounds like the Blitz with is Pssssss but it sounds quiet and it similar to a turbodiesel bus, lory, 18 wheeler, whatever you wanna call it.
Turbo XS BOVs have a hard problem with staying close when at idle, this is due to spring pressures. However Ive known people to use them on 4cyl. without any problems perhaps cause the 4-cyl. doesnt create as much vacuum pressures as the larger 6-cyl. Either way its a cheap and effective BOV if you can get it to work.
When you vent atmosperically you will need to tune out the stumble with the S-AFC. Stumble isnt really pronounced but can be felt shifting at certain RPMs.
the choo choo choo sound you are referring to is air not being released by the BOV due to low boost
instead the air passes back through the turbo, the sound you hear is air being 'chopped' by the turbo blades and exiting through the filter. it has nothing to do with the BOV
my recommendation is HKS SSQ and if you put it on the intercooler pipe after the intercooler core then you will only need 1!
as shown in the pic above?
i've got pod air filters now, and it makes a bit of a PSSH when u boot it but i want it louder. will the HKS SSQ do this for me?
my only prob with the HKS SSQ is its price!...nearly $700 :)
how much horsepower can the SSQ handle?
another question....
on the autospeed website the HKS SSQ valves are $567 for a universal one and $1,095 for a kit for the GTR
it says the kit includes all needed mounting brackets, mounting flanges and piping for each specific application.
is it hard to make up your own adapter, and does it cost much?
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
