25 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 132
ok trying to set this up for the 28th but am having a prob's with Darlington Park, I have sent them emails asking for info & left phone messages with them & still have not gotten back to me starting to piss me off :( so will try & get time tomorrow to give them a call & get it sorted :(
https://www.sau.com.au/forums/topic/47630-go-karting/page/3/#findComment-978188
Yeah I bought them along to the skidpan day I went to and they had a blast sittin in the back, but they are a bit young to drive karts, 5yrs and 3 yrs :) But dont change dates on account of me, there will always be next time ;)
https://www.sau.com.au/forums/topic/47630-go-karting/page/3/#findComment-979181
Ok people It is set
Place --> Darlington Park
Date --> 04/09/04
Time --> 3:30pm
Cost --> $65
Maps are up it is exit 38 off the M1 coming down off the ramp go around under the highway & take Stanmore Rd & then travel down Stanmore Rd take Peachy Rd (left Turn) & is a little way along Peachy Rd :)
It is set so come one come all
Cheers Mike
List To Date 17/08
Oz
4 Doorz
Knore
Nexus9 (Y 4 D PARK)
Wados +1 (Y 4 D PARK)
Strutto (Y 4 D PARK)
Melv (Y 4 D PARK)
Twoquik
RB25
Charly
Chaos
Jaqule (Y 4 D PARK)
Mick51 + 3ppl (ether D Park or Kingston)
Slamm
Lazy-Bastard (Y 4 D PARK)
Ska (Y 4 D PARK)
Maybe
Growtalski
Evo83 + 5
33 Niz
Nizmo-Boy
https://www.sau.com.au/forums/topic/47630-go-karting/page/3/#findComment-982520
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
