3 piece forged NOX wheels 20x10.5 +12 off my R34 GTR gloss black dish satin black centre falken tyres front tyres are almost new ,rears are fairly new ,stud patterns 5x114.3 $3000
R34 GTR mechanical non vspec diff 3:545 ratio with nismo 1.5 way diff centre assembled by award diff $2999
Brand new Alpha&omega 350mm rear brake kit evo 8 rear calipers powdercoated white ,geniune brembo brake seals ,dba t3 4000 brake rotors ,winwax w3 pads and braided brake lines to suit $1999 hasnt been used since fitted
Brand new high octane racing billet rear driveshaft inserts $1000 or if someone wants a full set $2000
Rare R34 gtr non vspec crown wheel and pinion 3:545 ratio ready for a aftermarket diff centre will fit into any non vspec diff housing will throw in other spares everything that in the container are all 34 non vspec pieces $750
Brand new Plazmaman 85mm throttle body with hdi clamp welded on with s15 throttle cable to suit $750
Brand new Precision 66mm wastegate brand new in box $665
R34 gtr back half of tailshaft $350
R32 gtr front half of tailshaft $250
R34 gtr power steering hardlines with brand
new pressure switch $250
R32/33 gtr drivers side front shaft suits reco $200
2x Geniune BBS LM F1 black and gold centre caps $150
R34 gtr factory wheel nuts full set 20 pieces $50
R32 gtr gearbox crossmember $50
R34 gtr/gtt boot brake light $50
Rb26 bottom timing cover $50
Rb26 backing plate $50IMG_8403.jpgIMG_8404.jpgIMG_8405.jpgIMG_8425.jpgIMG_8436.jpgIMG_8419.jpgIMG_8418.jpgIMG_8420.jpgIMG_8424.jpgIMG_8430.jpgIMG_8412.jpg
https://www.sau.com.au/forums/topic/476753-gtr-part-galore/
Brand new Alpha&omega 350mm rear brake kit evo 8 rear calipers powdercoated white ,geniune brembo brake seals ,dba t3 4000 brake rotors ,winwax w3 pads and braided brake lines to suit hasnt been used since fitted $1750 or will swap for r32 33 34 gtr rear brembo kit calipers pads rotors and brake lines with $1000 my way
Brand new Precision 66mm wastegate in the box $650
Brand new Plazmaman 85mm throttle body with hdi clamp welded on ,throttle cable included $600
R34 gtr non vspec crown wheel and pinion 3:545 ratio it will fit into any non vspec diff housing $550 will throw in a housing so all you need is a aftermarket diff centre and off you go
R34 gtr back half of tailshaft $300
R32 gtr front half of tailshaft $200
new pressure switch $200
R32/33 gtr drivers side front shaft suits reco $150
2x Geniune BBS LM F1 black and gold bbs logo centre caps $120
Rb26 girdle $50
https://www.sau.com.au/forums/topic/476753-gtr-part-galore/#findComment-7904902
  • 1 month later...
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
