Car is in good condition having been well looked after and serviced regularly. Done 115xxx km. Been garaged and looked after in a fastidious manner. Major service completed at Import Revolution.
OTHER FEATURES:
- 244.6kW 3.7 litre engine with 7 speed semi-auto with paddle shift
- 20 inch wheels (Mars Performance MP-MS Hyper Sylver )- front 9.5 +18 rear 10 +15 with 235 35 20 and 255 35 20
- Blitz adjustable  coil-overs -  height and damper
- Magnaflow axle back exhaust with custom 2.5 pipes from cat-back (not loud at all)
- Logbook service from japan (i believe up to 60000km)
- All service in Australia done by Import Revolution Bayswater
Car was imported to aus in 2015 with 82xxxx Km auction grade 4 Interior B and i am the first owner since November 2015
Since move to new area its barely get driven hence i am considering to sell.
Happy to get a RWC for an additional cost once a reasonable deposit received.
Price : $21000
Contact : 0424565779
Uploaded Images
48 kb · Done
126 kb · Done
Edited by Danushka
  • Like 1
https://www.sau.com.au/forums/topic/476842-v36-type-s-2009/
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
