gday
what is the fuga and has it been released there??
i remember reading about it in one of the posts on here confusing it with the new skyline
reason i ask is i beleive i saw one or a prototype or something like that in the rocks under the sydney harbour bridge today the area was kind of blocked off and drove by a few times trying to figure out what was going on.
pretty sure it was a nissan, might have said fugama or something? but figured it to be the fuga
https://www.sau.com.au/forums/topic/47700-fuga/
Fuga is the replacement for the current Y34 Cedric/Gloria. Nissan decided to change the name for the new model to "Fuga" because the overall dimentions of the car push the Fuga into the large sedan class. The Fuga will be sold in Japan in 2.5L and 3.5L V6 RWD and 4WD versions, with Infiniti M45 model carrying a 4.5L V8 (possibly the V6 engine options too, but I couldn't care less).
https://www.sau.com.au/forums/topic/47700-fuga/#findComment-962902
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
