Hi guys,
Last time I took my R33 GTST to the drags was 12 years ago - back then I did 5 runs, snuck into 13s on the last run (13.94 @ 106MPH) and was happy with that and drove home.
I'm heading out tomorrow to Willowbank with some mates for a bit of fun and looking for tips - including reducing the risk of breakages and being able to drive home ?.
Mods - Power FC, FMIC, oil cooler, boost controller, HKS2530 turbo, NPC organic single plate clutch without many km on it + NPC lightened flywheel.
Stock manual gearbox and diff, cheap street tyres (Achilles) with plenty of tread, 245x45x18.
Dynoed at 234 RWKW on PULP 98
Fresh oil, brakes pads/rotors/fluid are in good nick
I've read a bunch of posts in this forum that include advice such as:
  • remove extra weight (in my case that would only be the spare wheel, jack etc
  • have 1/2 tank fuel, not full
  • lower the rear tyre pressure (I'll have a pump to re-inflate).
My old 2530 turbo is a bit laggy, so I know that I'll have to slip the clutch to get the old girl off the line.
The other guys I'm going with will likely be in high 12s/low 13s (chipped BMW M2 and C43 Merc - both autos), so there'll be a temptation to push things a bit - and I'm seeking guidance on getting reasonable ETs while minimising the risk of breakages (and I accept there's always a risk I'll break something)
I have questions such as:
  • what sort of revs do you try to leave the start line at?
  • is there any point in doing a burn out on street tyres? I would assume some benefit is gained from a warm tyre compared to cold?
  • depending on the number of people running - especially at the start of the session - there may be opportunities to do back to back runs with minimal time between - if oil and water temps are fine, do I just line up again, or should I give the clutch some time to cool down?
  • The car doesn't get driven much - I've got 1/2 tank of P98 but it's 2 months old - should I throw in a bottle of octane booster?
  • any other tips on getting good ETs in a manual Skyline with minor mods?
It will be a fun night - beating the BMW or the Merc is unlikely, but if I cut a better reaction time and get a good launch I may beat them over the line even with a slower ET....that's the stretch target...
Getting an ET around 13.5s (or better) and driving home after is the primary target ?
cheers
Mike
4-4.5k rpm
Burnouts are fun, don't do a big one, run your tyre pressure at about 25 psi and see how that goes
If your temps are fine go for it
Sure, why not
Practice, don't worry about racing the guy in the next lane, stage, grab your handbrake, wait for the green, bring the revs up to "whatever", launch hard and punish the clutch a bit, don't hit the limiter, stay in your lane, don't back off till you pass the line.
Profit
Have fun, play with tyre pressures, do some skids
Disclaimer: street tyres are shit
1 hour ago, mlr said:
4-4.5k rpm
Sure, why not
Profit
nice...so get some runs up prior to running against any of "the guys in the crew" to begin to learn how to launch - and have fun.
Great post - cheers
Mike
well I had fun, but my times were shite - my mate in his BMW M2 ran a 12.9 while I was still waiting in the lanes - I knew I couldn't touch that.
My best time was 14.4 @ 104mph - a lot slower than the 13.94 I ran 12 years ago :(
And 14.4 was my first run...later runs where I thought my start was better were slower.:(:(
The only redeeming part of the night was beating a WRX STi
I'd completely forgotten how much is going on when trying to get off the line fast in a manual and how different it is with a helmet on...
...and later runs where I didn't try for a good reaction time, but tried for a better launch and riding the clutch more to not bog down were slower - likely I was frying the tyres and the clutch at the same time ...
Disappointed I couldn't get close to the time I ran 12 years ago - the car feels faster and the power comes on harder but I am running less rubber - 12 years ago I was running 265x35x18, now they're 245x45x18...I might have to try some drag radials.
cheers
Mike
cheers
Mike
Post a slip or two.
Did you play with your pressures.
Those tyres are shit though.
Was 104 mph the best, what weight is your car?
If your around 1550kg with your 104 mph you are around 220kw and 13.6 ish.
Service car, get some better tyres and go again, but, 13.5 is about it I'm a guessing.
Currently my NA 2.0 86 is 0.1 sec quicker than your turbo 2.5.
car is full weight R33 GTST coupe
timeslips attached
I dropped pressure to 25 psi at the start before any runs, but didn't muck from there
oh dear :(
cheers
Mike
Edited by mikel
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
