Hi all, I'm wanting to change the weather strip around the the windows marked in the picture. Any tips on how to do that? Might be a stupid question but yeah any advice would be great! Ilooked on Nengun to get parts. who would I go to to replace these?
Kind regards,
Andre.
https://www.sau.com.au/forums/topic/478330-weather-strip/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
