R31Nismoid:
ok so you are going on a chassis dyno to run the engine in.
are they going to do a full power run/tune? I understand you have a GT30 so are you going to take a freshyly rebuilt engine on a chassis dyno, do a few ramp ups to bed the rings in and then go all out 20psi 7500rpm power run and tune?
R31Nismoid:
I shall ask the question tomorrow of how it is all going to work.
But i beleive thats whats going to happen, once i drive out the roller door.
But yeah, ill find out in detail tomorrow
that'd be tops (Y)
then i can get more info and pass it onto my dyno guys.
Reckon you could find out the procedure for run in to etc and what it involves? They may keep it secret tho :S
I reckon i can indeed. I was getting told the plan of attack two weeks ago as i asked about running in and stuff and i was met with an odd look (i now know why)
I was told that he was sick of running in race motors as it took so damn long, so he didnt bother anymore.
After a 6 month hiding on the track, he would pull em apart and they'd look no different to a motor than spend hours & hours being "run-in"
So no long winded running in.
anyway, more to follow tomoz
Mine will be thrown on a car trailer and towed down to Shauns where he will run it in there.
I am curious as to how spot on the powerfc's base map is AFR' wise.
I will find out tomorrow I guess. :D Won't I Darren ;)
Son of a bi....:) Can i borrow your guineapig suit then? :)
haha i was met with that exact same look when i asked the same question...
mine should be due early next week and from what iv been told, by the time the car has been tuned up itll be ready to go without any "running in"
he (Ian at Amberly) said running in is an old term, when it comes to purpose built engines, all clearence and measure are done pretty much exact
who knows...but id belive what the builder says, especially if theres repuation to back his claims on engine building, not something someone wrote in a magazine
rings still need to be bed in properly. If they say something along the lines of what was siad above, id assume they are taking your car for a few hundred kms of run in driving....clearances done pretty much exact :bahaha: it would want to be, but rings still need to bed :)
Speaking to somebody yesterday about running in engines and was told similar to what R31nismoid and whistla said.
"Purpose built performance engines actually dont need as much running in as a mass produced ( falcon,commo) engine. Mass produced engines have less tension in the rings and therefore need a longer run in period to bed them properley. Whereas a performance engine will generally have a higher ring tension and bed a lot easier and faster. Car manufacturers have low tension rings as it creates less friction = less wear = better fuel economy."
But nonetheless rings still need to bed, no matter what engine they are in.
do u guys know how long a motor from Holden is "run in" fpr instance??
I do... and if you find out you'd see most others' point.
The fire em up (on mobil 1 sythetic) give a squirt check everything is in order (pressures etc etc) and whack em into the cars. They dont spend hours on an engine dyno or anything bedding in rigns blah blah. Not as if thier motors dont last many 100,000's of km's
Rings dont take hundreds of KM's to be bedded in.
I took put my stardard computer in my RB30DET to start it up. I drove it to the workshop and put it on the dyno. They told me it was running very lean, so i put my wolf in and they tuned it for right mixtures up to a 4000rpm rev limit while running it in. It is geting fully tuned after ive done 1000km, since ive just got to bed the rings in. Im glad i got the mixtures checked because i could have done damage. Will find out how much power its got by wednesday.
Yes Ash, I know what the manufacturers do. I also read somewhere that sometimes the engines are taken to redline to ensure everything is ok.
But you said : "do u guys know how long a motor from Holden is "run in" for instance??"
That is a misleading comment in the sense that a new car owner is not told there engine is ready for "normal" use. You are told you have to run it in and it is in the owners manual explaining the manufacturers recommendations on how they want you to do it.
A perfect example I would love to see is the GEN 3 engine. One driven hard from the outset and one ran in on the dyno as per Holdens recomendations. And then see which one has the better oil consumption.
I dont agree that a performance engine needs a long drawn out run in process but I also dont agree that it can be taken to the limit from the get go.
Whistla wrote: by the time the car has been tuned up itll be ready to go without any "running in"
Can you ask your builder approx. how many ks will it take for it to be "tuned up"
mine (same as mr whislta) will prob be done on dyno and thats it :)
Hi Ash, I think you will find that he will run her up on the dyno for initial break in and tune then advise you to come back after around 500 km's. In my experience he also knocked out a few degrees of total advance during the break in period.
yeah i think i'll take mine to get the mixtures checked out, this dyno time will also be loading it up a little helping bed the rings in... once the mixtures are ok, go driving for 500-1000km's then come back and say 'boost this mofo right up' :)
yeah i think i'll take mine to get the mixtures checked out, this dyno time will also be loading it up a little helping bed the rings in... once the mixtures are ok, go driving for 500-1000km's then come back and say 'boost this mofo right up' :P
exactly what i was told...and will be saying :D....500-1000kms is the critical bit, then let it fly :rofl:
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
