Hi Chris
even know I'm new to this forum I have a couple of things that I would like to ask they're,
1. English translation for the fuse box inside the car for V35.G35 2003.
Which my other problems might b related to the fuses not sure,I need your advice please.
2. My boot latch won't open the boot, I have to put the top of back seat down to pull the latch handle to open. ?
3. The clock stays on 1.00 o'clock or goes back to start at 1.00 every time it's started n stopped. ?
4. My indicators don't show on the dash they r on I've checked but don't beep or reversing it doesn't beep either. ?
5. Passenger side window gets sticky but most of the time won't work n the drivers window goes up little bit to much which I can fix that by flicking the reds in dash on n off again but don't understand why. ?
Lastly
6. Wen reversing the mirrors stopped moving into position to do so same as my camera's the back n the 2 at the front on the tv, they did then suddenly stopped working, same time the cameras stopped so did all of the other little things like mirrors stopped, the indicators stopped beeping, in reverse stopped beeping, the engine check light came on,
so I'm so hoping for advice off u wot to do or where to start addressing these issues basically, hoping it's a simple fix like fuses or something please help, also based in Melbourne Victoria so if u know of anyone in my area to refer me too if u don't know about these issues would b greatly appreciated.
Thanks guys as I'm eagerly waiting for you to reply, thanks. Chris.
Edited by millandadewey1
Left out a word.
https://www.sau.com.au/forums/topic/480507-millz/
Great great we do, thank u, n I got all new fuses put m in n everything is back to normal but I'd still love to get the translation for future but the boot latch still doesn't work, don't no y, n my husband found a disc in the car n cause we only bought car recent n after looking at somethings on the car figured out the disc was English version of the navigation system n maps work great now, my lucky day! I'll attach that pic too u asked for n any info on the boot if I'm not pushing my luck ?IMG_20200601_003334.thumb.jpg.70776db3f7d5fb2a3aa2f8298d85133b.jpg
https://www.sau.com.au/forums/topic/480507-millz/#findComment-7932048
N my dash needs translation too, have any idea bout those, I'll attach a pic.
The tv we've fix my hubby got the software onto disc put it in n works great but it's the buttons there if u knew those too by any chance sorry if I'm being annoying.
https://www.sau.com.au/forums/topic/480507-millz/#findComment-7932049
Hey mate, quick caveat - I'm not native Japanese, but my translation should be close enough for it to make sense.
1. This disk can't be recognised
2. Guide
3. Screen (or referring to the image on a screen)
4. Bird view. I'm guessing this is GPS or reversing camera?
5. Vehicle information (I'm not 100% sure on this one)
6. Map
7. Menu
8. Picture quality
9. Zoom in
10. Zoom out
11. Return
  • Like 1
  • Thanks 1
https://www.sau.com.au/forums/topic/480507-millz/#findComment-7932057
1. Look at the fuses indicated capacity, please don't put in the wrong sized fuse
2. Regarding other electrical components, please meet with the sales team
3. Up
4. Injector ENG control
5. Mirror control
6. Cigarette lighter
7. Fuse (can't translate fully, photo too blurry)
8. Mirror heater
9. Starter signal
10. Blower motor
11. Blower motor
12. Electronic components/parts
13. Air bag
14. Meter/gauge
15. o2 sensor
16. Audio
17. Electronic components/parts
18. Brake lights
19. Interior lights
20. Boot opener
If you want the translation for #7, post up a high res photo of it. The photo you uploaded is too blurry for me to read.
  • Like 1
  • Thanks 1
https://www.sau.com.au/forums/topic/480507-millz/#findComment-7932058
The top picture means to decide, it might act as a select button when your in a menu as a guess.
The bottom picture roughly translates to -
If it's the case that you want to cancel turning off the screen, please push the "picture quality" button again.
  • Thanks 1
https://www.sau.com.au/forums/topic/480507-millz/#findComment-7932091
1 hour ago, millandadewey1 said:
IMG_20200601_182509.jpg.18c05181cc860413cfd2b00b3091dc0e.jpgIMG20200601151738.thumb.jpg.e49ec346cfee02c38b280c32e0ef660b.jpg
Thanks mate legend u have made my week n it's only just started LoL, while I have u I was curious bout my key, with the 3 buttons on it ya, so wots the 3rd one do, is it a boot button or is it only the interior button for the boot n it something else ? Because I have a problem opening it, the one inside the car doesn't work n I have to go through the back seat atm ?
https://www.sau.com.au/forums/topic/480507-millz/#findComment-7932093
No worries mate, happy to help.
Umm, I'm not familiar with the later model skylines. Does the key have any writing or pictures on it?
The only thing I can think of that might be catching you up, some of the earlier model skylines have a latch that if it's down, the boot wont open using the boot release. Maybe check your boot latch and see if it has the 'valet mode' latch.
https://www.sau.com.au/forums/topic/480507-millz/#findComment-7932094
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
