Hi everyone,
Ive done a search, though I cant find exactly what  I'm asking here. The cold start valve(under the TB on the rb20det), what voltage does it see at the plug? Is it 12v? And when does it see a voltage? Cold engine, ignition on(engine not running), should I be seeing a voltage at the plug for the valve?
Im not getting a voltage under this scenario, if I'm  suppose to, any ideas on where to look to fault find this? I've finally had enough of the horrible cold starts and rough warm idle problems and I'm finally doing something about it.
Thanks everyone!
https://www.sau.com.au/forums/topic/480775-cold-start-valve-wire-power-voltage/
Ok, so this means it should have a constant 12v signal with ignition on? The fuel pump fires up and runs, so its getting a signal to run.
Ive pulled the cold start valve apart, its dead clean inside, I've hit it with 12v and nothing happens. I can move the pcb with my hand forward and back against the spring, though I'm not sure what normal operation is meant to be with a 12v signal.
Thanks
It's super slow acting valve, not something that reacts fast like your idle control valve or similar.
They often die on RB20DETs and you see hacks where people just block the air feed to it to prevent super high idle.
11 minutes ago, mtopxsecret6 said:
Does anyone know which is positive and negative on the plug?
Thanks
test which terminal has continuity to earth = -ve
Easiest to test if you remove it.
Look through where the hoses fit. There should be a shutter, and it should be roughly half open at ambient temp. Then apply battery voltage across the terminals - the shutter should fully close (takes several minutes).
Check resistance across the terminals - 70 - 80ohms at 20C
Why didn't i think of this! Haha
Ive tested the ohms, its 75 as stated on the plug. The opening isnt quite half way, its more a quarter. And ive had it sitting on the test bench and it has moved. To a closed position. Is there a process to open the valve a bit more to get it to half way? Ive attached a photo of mine at the cold position, you can just make out its on the quarter open position. So for some reason I have no power at the plug through the loom.
Well, it appears that it is pretty much working correctly.
Upon reflection, the symptoms you describe - poor cold start, poor hot idle - don't seem to mesh. I would start looking at dirty injectors. Try a big chunk of injector cleaner in your next tank of fuel.
Have you confirmed that the fuel pressure is ok? Base ignition timing? Water temp sender?
Edited by blind_elk
I'm m not getting power to either of the solenoids, so I'm confident this is the issue.
Both leads on the cold start valve is earthing out. And with a cold engine, I have no power at the AAC valve plug, I did momentarily have some yesterday.
I had the injectors cleaned, fuel is at 50psi, not sure how to test ignition timing.
I'm going to swap ecus and see if that has anything to do with it.
Don't do this. If there is a fault in the wiring that has damaged the relevant circuit in the ECU, then swaptronics is a good way to kill another ECU.**
Instead, why not look into the health of the loom? Point to point check the wiring with a multi-meter. Use the wiring diagrams in the manual to show you what you should be looking for and where.
** Granted, the power for this valve does not come directly out of the ECU, so the risk to your spare ECU in this circumstance is not high. I'm just making a point that you need to think about what you're doing, instead of risking spare parts. Swaptronics is bad practice.
Where do I find this wiring manual? Is it a file on the website?
Air Reg / AAC problems have to be unrelated.
AAC is powered by the ECU relay, and the ECU switches to earth thru pin 4.
Edited by blind_elk
AAC is powered by the ECU relay, and the ECU switches to earth thru pins 4 and 60.
I'm waiting for a new AAC valve, the cold start is working on the test bench. And it turns out when you crank the motor thats when the fuel pump relay kicks in, and you get power to those two plugs.. Durr..
So, the solenoid on the AAC is cactus, so that explains why that wont work, and I believe the cold start may have been just jammed etc. I pulled it apart, hit it with electrical cleaner, and I'm m currently cycling it on the test bench atm, and it seems to be operating.
When I get the new AAC valve, I can continue this adventure, and give progress updates.
Thanks for the help/brainstorming so far everyone!
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
