Price: $2,500 neg.
Stud: 5x114.3
Size: 18x9.5 +20 offset (square)
Wrapped in Yokohama Advan AD08R with more than 60% tread. 255x35.
Price is negotiable within reason. Not desperate to sell though so keep the lowballs to yourself. These are gorgeous deep concave wheels discontinued by Work and replaced bt the T7r, which in my (and many others) opinion, the XT7 is a much cleaner design. The bronze is killer, look unreal on a black/white/grey cars and they’re absolutely perfect fitment on a 32GTR. See photo of them on mine. Also clear big brake kits. I have Evo9 Brembos and 350mm rotors, huge clearance. Two are in perfect condition, two have slight nicks on the very rim. Barely noticeable. See photos of individual wheels.
No buckles. No cracks. Located Hillside VIC for pickup. You're welcome to organise your own courier if require. IMG_5788.thumb.JPG.af4a2ec13d2fca6e308d1128a72bec8a.JPG
IMG_5464.thumb.JPG.490fcc817ffb2fe00eabe62d4ad67764.JPGIMG_5789.thumb.JPG.6555be5d8980ceb9682c808e51c2eb99.JPG
IMG_5785.thumb.JPG.e7eeddecbb5937cee67a37df5eb0df2a.JPGIMG_5784.thumb.JPG.93850bf53cc18fc056aeee23b45be7f4.JPGIMG_5783.thumb.JPG.76a8dc4d20556de7467a19cd22bd59eb.JPG
IMG_5781.thumb.JPG.fd65af1b1b55a229c6ddfec3e659af0d.JPGIMG_5782.thumb.JPG.bf66bc9dcd53aee6f7f78e3d0b82e6fb.JPGIMG_5780.thumb.jpg.9fdb0213e8e5c0a1ea98f5cce07bd708.jpgIMG_5779.thumb.jpg.f9382a5067d3379d1b11811d0e6f733f.jpg
Thanks for looking.
https://www.sau.com.au/forums/topic/481777-work-xt7-wheels-with-yokohama-ad08r/
  • 4 weeks later...
  • 3 weeks later...
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
