Hi,
In short my problem is that since my mechanic fixed a wiring issue,
- the range for unlocking my car is severely reduced (5m down from like 40m)
- when you hit the lock button several times the headlights no longer come on (as they used to to help you see it when you lose it in the car park)
- my left wing mirror doesn't fold in when locked (the right one still does)
The work he did was to fix the bundle of wires that go to the back of the car - some had shorted together. He also disconnected the battery at the time to reset the computer.
I have also had an issue (in the past) with water leaking from above the windscreen down into the body control module - since "fixed" by drying and silicone spraying the module. Water is not an issue this time round as the car is bone dry.
I suspect that the issue is a result of the work that the mechanic last did. But I don't know where the problem would be: intelligent key module, wiring, BCM, a mix of the above.
Also not sure of there is somehow a software glitch as a result of disconnecting the battery.
Edited by Bentley88
https://www.sau.com.au/forums/topic/481870-perplexing-issue-with-intelli-key/
Sounds like a few possible causes.
Bad earth.
Group of wires pinched together to tight so that they get crossed wired.
If you have a Dash Cam with the USB cable running down the A Pillar it can interfere with your key.
Left mirror still folds in when you activate it?
Electronics sometimes do strange things :wacko:
  • Thanks 1
Yeah could very well be the wiring, I might have a look and see if there is anything obvious in the area the mechanic worked. Bad earth also a good suggestion.
No dash cam in the car.
Left mirror doesn't fold at in response to locking/unlocking. But it can still be adjusted from the drivers side via the toggle...
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
    • That's some really horrible design with the way it's cut/shaped! Is there much damage to the box that failed in? IE, new fork and you can go again, or is it a total rebuild again? Id be trying to build that piece from scratch, and getting some reliefs added in the corner to hopefully stop breakage, and then swapping boxes ASAP, and then doing the same to the currently good working box. I'm assuming hard shifts have not been friendly to it!
