Hey Guys
I asked this question awhile ago but never got a straight answer so thought I'd ask again.
I have a SAFC thats allready tuned on my R33, suppose I was to reset my ECU (i.e. unplug the battery and bleed the electrical system).
When I start my car again the ECU does a few diagnostics of some kind right?
Is this affected by my SAFC settings?
Hey Guys
Hows it going
I was thinking about getting an S-AFC II, but the thing is I havent got a full exhaust, cat back only, a Hybrid 800 x 600 Front Mount Intercooler and a Turbosmart Bleed Valve, I was wandering if you recommend finishing off my exhaust system (dump pipe and hi flow cat) or getting the SAFC-II.
Is there a great amount of difference that the AFC makes?
Another thing, what mods do you have on your car since you have an AFC.
Thank you
thx INASNT I guess I am worrying about nothing, just wanted to make sure
DezertEagle, honestly I think if you're planning to keep standard turbo and/or ECU then yea the SAFC is worthed. Im still using standard dump though Ive change my front pipe and have a high flow cat.
I bought the SAFC because, due to the high boost and all my mods the ECU was hitting the fuel/boost cut so I wanted a quickfix and the SAFC solved that. If your car is allready experiencing this then I suggest the SAFC first, if not I would finish of the exhaust system and think about where to go after that. Personally I'd like to go full programmable ECU sometime in the near future.
My mods are:
Trust MX cat-back
SS highflow cat
RSR front pipe with stock dump pipe
Apexi filter
TRUST V-SPL intercooler kit
SAFC-II
Greddy Profec B EBC
HKS 256 exhaust cam 8.8mm lift with cam gears
Bosch 910 external pump
malapassi FPR
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
