Hope someone may have an answer who browses here. Before going the full on Link ECU route or sending the car off to UP Garage here in the states, I wanted to do some checks on my 94 R32 GTR using the consult port.
TLDR: Consult Port not connecting to ECU no matter what I tried, even splicing direct into the cable and hardwiring the USB adapters.
I currently have cable wise:
- 1x PLMS Consult Cable
- 1x Ebay Consult Cable
- Nisscan/ECUTalk/Nistune/Conzult Software
Before my tests:
- Made sure all software and drivers were correct
- Made sure that the Power and RX lights were showing that they were functioning from the correct Windows COM port (for both cables)
- Read all of the Nistune connection error docs
- Made sure there was continuity between the ECU and the Consult Port on ECU Pins:
--Pin 21: RX (Yellow/Green Stripe)
--Pin 22: TX (Yellow)
--Pin 31: Clock (Yellow/Red Stripe)
--Pin 45: Ignition (Black/Red)
--Pin 50: Ground (Black)
- My ECU is STOCK as far as I am aware, with the Nissan stickers still sealed around it.
- Checked that the Clock is at the specified 153Khz rate on both adapters
-Baud rate of 9600
Tests done with Both cables
Test 1:
- Plugged in Consult Cable to Port in Fuse Box, Plugged into laptop, open up ECUtalk, select COM port for the device (usually 3 or 4 for my system)
- Hit connect, the RX light blinks, then nothing.
Test 2:
- Plugged in Consult Cables etc etc, Opened up Nissan Datascan, selected the correct COM Port, and then hit FIND ECU.
- Nothing is registered when it does the scan, nor when I select connect.
Test 3:
- Got fed up trying all the different methods and driver reinstalls/trying different COM ports so I decided to chop the TX/RX/CLK wires right by the ECU and add quick connects. (with Ignition and Ground coming from a separate spot that one of my gauges is hooked up to)
- Even when Plugged directly into the harness right next to the ECU, the ECU does not respond or send out a TX signal to the adapter.
At this point I don't know what else do to try and get the ECU to respond to my adapters. Any ideas? Anyone else had any luck with Datascan and their Consult Port?
It's a better than even chance that someone has hamfisted it in the past and burnt tracks in the ECU. Open the ECU and look closely (magnifying glass) at whatever tracks you can see that run from the Consult related connector pins. There might be something visible. Of course, there might not. There's pull up resistors and other doohickies involved in those connections that can get trashed without showing much in the way of burn.
The Consult related tracks could also conceivably have been damaged in an unrelated incident. It's not unknown for injector or ignition drivers to get destroyed, taking out tracks. It might have been repaired - but only repairing the things needed to make it run the engine. There's a million scenarios like that.
On 3/14/2022 at 11:56 AM, qthegaijin said:
trying out the Jumper method to see if the dash lights blink out the codes
R32 ECUs have a switch/potentiometer accessible through a small hole in the side of the case that is used to trigger fault code display. How to use it is covered in the workshop manual. You basically have to just turn it all the way one way then all the way back, or something equally simple (and long forgotten, in my case, having replaced the whole thing with an R34 ECU).
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
